911 Forum 1964-1989
911SC Alternator
Old Dec 10, 2002 | 10:28 AM
Feeding a 911 for a while's Avatar
Post 911SC Alternator
My '78 SC has worn alternator bearings. They are not yet so bad that the fan rubs on the housing but they are noisy. My question is:- can the unit be dismantled and the bearings replaced? ?I do have acces to a certain amount of workshop equipment so I am able to press out bearings etc.
Any advicew would be greatly appreciated!
Old Dec 10, 2002 | 11:04 AM
Steve Wilwerding's Avatar
Steve Wilwerding
Post
Remove the altnernator and take it to a local alternator rebuilder. You could probably do it yourself, but rebuilders generally don't charge much to raplace bearings.
Old Dec 11, 2002 | 04:10 AM
Jeff Curtis's Avatar
Jeff Curtis
Post
I'll second that idea.
...just make sure they're familiar with a 911 alternator, they are "one of a kind".
Out local alternator/starter rebuild facility does a pretty good job on them, but tell them to use ORIGINAL PARTS!! The failure rate is fairly high when they use aftermarket parts from Japan/China...nothing against these parts/manufacturers except that I have witnessed a VERY high failure rate through our local P-Car facility. <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" />
Old Dec 12, 2002 | 02:18 PM
TCallas's Avatar
TCallas
Post
I agree with Jeff. Since the cost is so high on these and the remanufactured parts are not of great quality then a local rebuilder should replace the bearings but, use factory or OE bearings. They need to have previous experience or understand this unit first though.
