Charging circuit assistance.
Subscribe
Apr 14, 2009 | 11:22 PM
I had my alternator reconditioned about 2 weeks ago. The battery seems to have no trouble with starts.
But, the alternator warning light occassionally goes on when I decelerate to an idle. The idle speed is about 850 to 900. It doesn't do it everytime I return to idle. Sometimes the light is solid, other times is starts to light then goes out. It always goes out if I raise the idle to about 1000.
Should I remove the alternator and have the shop redo their work? Or, is this a typical pattern for our engines?
'88 Carrera
Reply 0
Apr 14, 2009 | 11:31 PM
that's not typical.
What reading do you get (volts) at the battery with all accessories turned off, at idle?
Reply 0
Apr 15, 2009 | 10:39 AM
check your belt tension
Reply 0
Apr 15, 2009 | 02:32 PM
It may take awhile for the new slip ring brushes to fully seat....
Reply 0
Subscribe
