Electrical problems...
Rusnak:
This is the second time I've done an alternator on a 911, so I'm at least somewhat familiar with the process. Interestingly, the first time I did it I had Al Reed polish and powder coat the fan and housing. When I put it back together, the blade tips just nicked the housing, and it was because of the powder coating. I had to sand tips of the blades to get the proper clearance.
The plastic deflector is already cracked a bit from the PO (or his wrench). I'll try to repair it before reassembly.
Thanks for the advice! Much appreciated.
