911 Forum 1964-1989
Brilliant {maybe} 911SC TRack Preparation Article
Old Jun 8, 2002 | 11:13 PM
Martin S.'s Avatar
Martin S.
25 Year Member
Post Brilliant {maybe} 911SC TRack Preparation Article
Noting that lots of the same questions come up time after time, and in searching around the Rennlist web site, I discovered an article I wrote a few years back. It may not be brilliant, BUT it does contain lots of information on preparing a 911SC for autocross, or the track. And believe me, I learned all the information the hard way as I campaigned a 80 Weissach coupe a few years back. As an example, I went through 3 iterations of oil coolers before I found the best fit for me and my needs, from stock loop cooler, to a Terbotrol, to a 87 Carrera with manual fan override switch and finally to the 934 valance with a center mounted oil cooler. The final iteration was the best.
I have since gone on to a 993...but I still love the 78 to 83 coupe, no sunroof preferred. You will find the article with this link:
<a href="http://tech.rennlist.com/performance/pdf/Staged%20Preparation%20of%20the%20911%20for%20Speed%20martinschacht.PDF" target="_blank">http://tech.rennlist.com/performance/pdf/Staged%20Preparation%20of%20the%20911%20for%20Speed%20martinschacht.PDF</a>
Old Jun 9, 2002 | 01:30 AM
Elephant Chuck's Avatar
Elephant Chuck
Former Vendor
Post
Brilliant, even if you have to say so yourself <img src="graemlins/roflmao.gif" border="0" alt="[hiha]" />
That's a good write up and gives a great overview for anyone starting out. Thanks for bringing it up.
Old Jun 9, 2002 | 02:58 PM
Martin S.'s Avatar
Martin S.
25 Year Member
Post
Thanks for the kind words...the article was written at a point in my life where the day job took very little time...not the case any more. I probably spent 80 hours, or more gathering data and organizing it into the final form.
I checked out Elephant Racing...great products, the track skin and the heat sink oil lines. I believe our mentor Bruce Anderson once wrote the the oil lines to and from the fender mounted 911 oil cooler contribute significantly to the cooling process. Converting these lines to a giant heat sink makes lots of sense.
<img src="graemlins/xyxwave.gif" border="0" alt="[bigbye]" />
