bolts for Recaro Pole Positions side mounts?
I bought Recaro Pole Positions used. The bolts supplied to attach them to the side mounts are short dome-heads w/5mm hex hole. Black, no specs on them. I don't know if they are OE w/Recaro or something the previous owner stuck in there.
They seem pretty whimpy.
Any one know the specs on bolt size? Should I get hex-head and washers?
(8.8 or better hardness I assume).
Thanks.
Thanks.
I've got all new B-K side mounts and a new Recaro Profi. It came with threaded inserts in the side of the shell. The B-K's came with socket head allen bolts-not sure of the exact size thread/diameter but they were about 20mm long.
