Stuck headlight
I just discovered that the PO broke the lever that moves the headlight capsule out so that the bulbs can be changed. The rod moves without engaging . It also wiggles back and forth so I believe it has broken free from hole that stabilizes it and gives torque to the bend in the rod. Right now the bulbs are fine, but I just know one day one of them will blow and I'll be right where I am now. Can someone suggest a way to get the unit out?
Thanks in advance.
Thanks in advance.
