Anyone bidding on this '89 911? Careful- not correct speedometer- mileage legit?
This car appears to have the earlier 911 speedometer- from maybe several years before 1989. Anyway, I've noticed this quite a bit on ebay and in general with the older 911s- the speedometer has been changed (easy to do in a 911), then the seller says he's representing the car for someone else (so they can claim they don't know about the replaced speedometer), then they claim the very low miles are original. If anyone is considering this car, I'd be careful. Someone should "make the seller aware" that the true miles are unkown, unless there is specific documentation that the speedometer was replaced with a unit that was dialed up to the exact mileage as the original speedometer (highly unlikely). I've seen this too many times...
http://cgi.ebay.com/ebaymotors/Porsc...fCarsQ5fTrucks
That is pretty rotten if the dealer and/or seller is omitting key information even while emphasizing low miles, unless of course they have supporting docs for a replacement piece. I'll volunteer as porsche-pinhead-for-justice and call the dealer myself if someone will provide some background on proper appearing speedometer for that year.
I figure odometer mileage reliability is already ambiguous enough as it is on older 911's-- just on account of the oem speedometers' commonplace mechanical failures..... & simply for the sake of all those with true, unadulterated mileage, I think it's imperative to call out intentional or unintentional misrep's wherever found.
Andrew911- what is the distinguishing feature that suggests speedo is from an earlier vintage?...is it the solid white circle/line?
I've seen 911SC's with the later 160 mph speedometers stuck in there, and similar switch-er-oos and typically no mention that the speedometer was switched or that the car was TMU (true mileage unkown). I have seen specific mention that the TMU on several 924/early 944 ads (maybe those odometers were more prone to failure), but the 911s for some reason people don't note.
I went on Evilbay and looked at 6-7 89's and none of them had that white circle.
I emailed the guy a couple days ago and he said he would talk to the owner and get back to me. He has not. I also notice that he posted another persons question... he did not post my question...
so something is not correct. Doubt he would get 30k (buy it now price) for an 89, low mileage or not... anyway but I hope no one gets screwed.
nice catch indeed!! Carfax is not air tight by any means but if the CF history is has consistent (at least annual) entries and no huge gaps then I would simply have to defer to my own investigative work.
For sure a physically incorrect speedo is a red flag but not necessarily a 'show stopper'.
If you're a newbie however, I can understand the urge to run away screaming.
I emailed him a photo of what the speedo should look like and I questioned the miles on the car. I doubt I will hear back from him and I am sure he wont post my question. I'll keep the board posted in the event he does get back to me.
It should look like this one...
Actually with regards to your last statement, I think a newbie might be impressed with the condition whereas I noticed the issue it right away (I'm on my 3rd 911 over the past 20 years...)
