Will 3.0L (SC) SSI's fit a 3.2L (Carrera)?
Hi Von:
Good price!!!
You can make them work on your 3.2 with some additional washers under each nut.
SC and Carrera ones differ only by port flange thickness. If you do this, be very careful on how you tighten them down to avoid warping the flanges.
Good price!!!
Von,
Be aware that SSI's are on the border of having pipes that are too small for optimal use on the 3.2L engine. They'll work, but you won't get the same benefit you'd get from a 3.0L or earlier engine.
