911 Forum 1964-1989
HELP!! - ANOTHER alternator question
Old May 11, 2003 | 04:10 PM
john d 81SC's Avatar
john d 81SC
Post HELP!! - ANOTHER alternator question
Swapping out an OEM external voltage regulator alternator for a new internal voltage regulator alternator in an 81 SC. Vertex faxed me a hand-drawn wiring diagram, which shows a completely different wire to terminal hook-up than the original (which Gilbert told me about). Is it unusual that the crimped fitting that fits over the 'pole' would be too small? Only this one set of brown wires doesn't fit over the pole indicated on the hand-drawn wiring diagram I was faxed - interestingly, it fits on the OTHER pole. All the other wires fit all the poles. With the alternator facing the front of the car, do the brown wires connect to the right pole, and the red wires connect to the left pole? Thank you in advance!
Old May 11, 2003 | 06:27 PM
Bill Gregory's Avatar
Bill Gregory
Technical Specialist
Lifetime Member
Post
John,
You have some email that may help....
