Throttle Switch Replacement? 89 911
I have an 89 911 Cab and get ready to replace the throttle switch - only problem is that I have no idea how to get to those damn screws. Especially the lower brachet screw. I was able to remove most of the wires harnesses and clear the area. I still can't get any size screw driver near that bottom bracket screw! I am more than willing to go to Sears today and pick up what ever type of tool will facilitate the removal process. Also, there is one harness attached to the Idle Control Valve bracket. It looks like the little arms around the wire harness was slightly crimped to hold it in place. Is that correct or do you just turn the harness to release it. I don't want to force it and risk breaking it. Thanks for any help. Andrew in Los Angeles
