See New Paint Job, now runs bad
We got the SC back with the new paint on it and it is an excellent job. Wind screen out, front and rrear lids off during the process. Now, we have a running problem. It sat in the shop for about 3 weeks and when picked up it will not idle and has a slight miss up to about 3000 rpm. 3000 to redline it seems to run normally strong. I did not see any wires or lines off/loose. Spark plugs and dist cap look good. I checked all the fuses. My guess is that it is lean in the lower rpm and maybe lean thru the whole rpm scale. I am going to try some injector cleaner tomorrow on the freeway. I have the manuals. Any guess as to what may be a quick fix?? (yeah I know, take the new paint off tee hee)
I'd also check/change the fuel & air filters - test the fuel pump perf, too . Is the batt & charging sys operating to spec? Interview the shop crew - how many miles did they put on the car, did they put an elect charge on the chassis, did they know how to start an SC properly, etc. Taking a car to a shop is like being in a hospital - there's always the chance you'll catch something new (& they don't fix the original problem, either) - sometimes it isn't even their fault. good luck.
I have had two problems come up after painting. One was a ground that was disconnected during removal of exterior parts. One was cut wires that were abraded by a stick being used to prop a hood.
I would also check for intake leaks and disturbed or old plug wires. Look around areas where masking off occurs, and consider a top up with fresh gas and some techron. Go for a nice long hot run.
PROBLEM SOLVED. New plugs, battery plus side not tight, and gas cap not tight. Wish I had done them one at a time--- I suspect the battery was the problem as I dont think the gas cap was an issue like on later cars..
