911 oil temp guage
I have an '81 911 with the oil temp guage that just shows the bars (no numbers) part # 31027485,5. and just purchased a guage from an earlier year with numbers, part#31027485,7. the back of the guages are identical but the new guage does not register any change. I have the brown wires set to the top post, the red/white wires set to the inside post and the green wire set to the outside post (as yhou look at the back of the guage).
what am I doing wrong? do I have it wired incorrectly or is there a different sender I need on the engine block?
thanks
thanks
I have a 69-76 sender i will sell you its part# 901 641 632 00 . I dont know if thats the one you need
