What to do...1971 or 1976
Hey folks,
For those that have much more knowledge and experience than me, what of these two 911's would you lean more toward buying:
A 1971 911T in good condition, but needing about 2-3k to make it a very nice condition 3 car. Not original paint, 90K on a non rebuilt engine, no rust.
A 1976 911S in very good condition needing just minor things. No air, recent rebuild, so so paint, a very solid driver.
Both cars are priced within a few hundred dollars of each other. I really like both cars and wanted some feedback from the experts.
Thanks,
Thanks,
Thanks guys,
The 71 has been repainted from it's original color to a complete different color. No rust, save a few surface spots.
What is the issues with the 76?
Whichever car is bought will only be a weekend driver.
The later car has the stigma of the 2.7 magnesium (vs. aluminum) case engine, which has a bad reputation for pulling head studs. If they are rebuilt properly they can be pretty reliable but many people are turned off by the reputation alone. Also the earlier car has that certain purity that is missing from the later cars. The later car is one of those 'tweener cars that is missing both the purity of the earlier cars and the robustness of the later ones. MHO...
Addicted Specialist
71 is a "long hood" ...no contest. So long as it's sound, get it and enjoy driving a true 911 classic. Worry about fixes later; address as you go ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Edward
Edward
Well all the 911's after 67 had Mg cases until the 76 Turbo came along when the switch was made back to Al for the 911 Turbo and Carrera 3.0. The 74-77 911's had numerous issues with 5 blade fans, overheating, thermal reactors and head studs, any decently maintained car has has all these issues resolved by now but the stigma remains. If the cars are the same price either the 71 is significantly underpriced if it isn't a POS or the 76 is significantly over priced. A decent 71 T should be 15-25K and 76 8-12K.
Phil
Phil
Thanks for the replies, here's the deal.
76 911S needing basically nothing, and paint 7 out of 10 with 12k on recent rebuild.......$13,100. (air does not blow cold but that doesn't bother me)
71 model with decent interior and rebuild 9k miles ago on non matching engine, has 72 FI. Color was changed from Green to Silver, small surface rust and needing tires........$12,700.
Both cars seem to run fine, and both are Targa's. Is the fact that the 71 has a different engine a "don't do it" sign or in the long run will that matter. I guess you could always go back to a 71 engine but it still won't match numbers wise, but how does it affect it's value.
Also, I'm looking for a car to keep not to buy and sell. I plan on using this car on weekends and local events, but if the engine makes that big of a difference in terms of value it would be nice to know.
Thanks in advance for any insight.
Brett
Go with the '71. I had a '76 and had the pleasure of having the 2.7 blow and leave me on the side of the road in the middle of nowhere...
Go with the long nose...
