Scary noise and thump when engaging torque, tranny/clutch/engine??? please read.
I went with a spring center clutch kit from Saks. Since doing the change, I've observed that the spring center clutch will transmit more noise from the tranny into the car, especially at low RPM's. I'm told that it's the rattle from the UNengaged gears that makes the noise, and the rubber center was better at masking it. I don't notice it at all anymore, and I found it reminded me not to lug the engine below 2000 RPM.
I sourced the parts myself and then brought everything to my indy mechanic. I believe labor was around $1200 or so for everything, but I'd have to go back to my records to know for sure.
* these items were not required for the clutch, but were leaking and/or worn out, so I replaced them while the engine was out.
The only item I ended up buying locally was the pivot shaft update, because I was unsure whether the kit from VertexAuto had needle bearings or bushings, and I knew which one the shop had in stock. Otherwise, I bought everything from these two places after shopping around online. Just after I placed my order, Vertex sent me a "10% off your order" coupon... oh well.
Germanimportedparts.com will ship for free if order is over $75. If you want a rubber-center disc, they have a kit for $850 IIRC. They will also price match (which I had them do with the clutch fork using Vertex's price).
And finally... thanks for the comment on my color - it's Diamond Blue, which actually looks more silver/grey than blue.
HTML Code:
Part Part No. Price Supplier Saks clutch kit (spring) CK4S 739 VertexAuto.com updated clutch fork 95011608606 135 VertexAuto.com pilot bearing 93110211100 6.01 germanimportedparts.com updated guide tube 95011681306 47.50 germanimportedparts.com pivot shaft update kit 964116710kit 179 VertexAuto.com Rear main seal 99911342641 17.55 germanimportedparts.com *fuel filter 92811025306 18.10 germanimportedparts.com *oil therm o-ring 99970731440 2.40 germanimportedparts.com *oil pressure sender 91160623000 7.29 germanimportedparts.com *sound pad 91155689101 54 VertexAuto.com
What kind of transmission is yours? Look like you are paying a little more than AASE quoted me. I went to AASE in Fullerton, CA and Jeff gave me a quote of $1,3xx include labor. The only parts he listed for me are the clutch disk and spring center (930-116-014-02) beside engine oil filter and oil. I made sure he used Saks parts. Yes, he said when they are apart, usually there are more parts need to be replaced but fork and bearing and such on G50 tranny is usually strong. His total labor is only $680.
On spring center disk, I have read many people can't take the rattle. Someone said he has to take it out after several days because it's annoying. So I worry, but Jeff confirmed that the spring center should last longer than the ruber disk.
Hey Pete, What is Marc's #?
[QUOTE=rnln;5785730] What kind of transmission is yours? Look like you are paying a little more than AASE quoted me. I went to AASE in Fullerton, CA and Jeff gave me a quote of $1,3xx include labor. [QUOTE]
That is right at what mine was looking at the pre-purchase recipt. Unless you like getting dirty, I'd let a shop do it.
Doug,
So your clutch was done at AASE too? I asked Pete for his opinion on this estimate. Hopefully he has the time to read it.
Like to get dirty? no. Like to save the cash and learn my car, hell yeah. But I don't think I have the right equipments and knowledge. I affraid that I won't be able to adjust/calibrate it right and it only last 6 months down the road.
Well, all it takes is learning how to eat only hotdog for months
Sorry I totally screwed up that post. No I didn't use AASE, I had the same thing done. (new clutch) It cost right at $1,200 in january '07. I do not know AASE, but the price sounds good for that job. I'd love to get under there with you. If you lived in Rancho too we could do it.
PS...I took the pictures of your car and my car togeather with me on my phone on our trip to saint lucia and showed a fiew people....every one assumed I had 2 911's. I didn't tell them any differant.
hey who knows in the future I might. Nothing better than BBQ, beer, and wrenches huh.
Thanks.
Thanks.
Well, you can tell them you got 3, just wait till the day Draco comes ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Team Owner
I had a diamond blue metalic 944 . What an awesome color, I would LOVE a 911 in that colour , at dawn and dusk it has a slight purple hue to the silver .. awesome colour
Draco came over for dinner and a drive and we both forgot to take a picture. He's got a sweet ride.
.....And to answer your PM I wouldn't recomend the shop that did mine. Quite the battle over price quoted and price charged. They were miles appart......
What kind of transmission is yours? Look like you are paying a little more than AASE quoted me. I went to AASE in Fullerton, CA and Jeff gave me a quote of $1,3xx include labor. The only parts he listed for me are the clutch disk and spring center (930-116-014-02) beside engine oil filter and oil. I made sure he used Saks parts. Yes, he said when they are apart, usually there are more parts need to be replaced but fork and bearing and such on G50 tranny is usually strong. His total labor is only $680..
rnln: Check your pm for my response to your questions. Please be aware that there is a drastic difference between the rubber hub disc used in early SCs, and the rubber hub disc used in G 50s. The G 50 clutch disc is a reliable, true long-life part, and I would wager that at least 95% of the G 50s in use today are still fitted with a rubber hub disc - unlike early SCs, which, if there are any original survivors I would be greatly surprised.
Important: https://rennlist.com/forums/showthre...+clutch+rattle
Isn't that funny....rnln has a post on the first page of that thread.
...and 2 years later, here we are.
What about a forum called zimmerlist.com?
AskPete.com is taken....
