track rims for my SC
I'm really confused about what rims will fit my '81 SC. I have Fuchs 6s & 7s X 16. I need a set of track rims but on my budget I can't get another set of Fuchs. what else will fit and what spacers will I need to get the proper fit.
please help a newbie. thanks
Addicted Specialist
I know you're on a budget (man do I know about this!!), but rims for track use is one of those areas you really need to be careful about as a failure here could be catastrophic to the car and/or you. Not to mention adding adapters (not really "spacers" as adapters have studs and bolt to the hubs) is another cost and hassle
That said, some good reasonably priced options that I would consider strong and "proven" are Fuchs and BBS. Yeah, I know you said no F's, but you can get a set of four 7x16s (you can run 205/225) for pretty cheap if they are cosmetically challenged.
Or, look for a set of BBS one-piece. The 3-piece ones are great (I have them like Ed), but will be on the pricey side. But the 1-piece BBS come up on ebay (or the various boards) pretty regularly, and will come in considerably less than Fuchs. Both of these also will have the right offset so fit is right on. Have patience ...best of luck!
Edward
Edward
Edward
Edward
As for the Rotas, I'd be very hesitant about them as I have not had good luck with them. They are beautiful wheels, but are relatively heavy and quality control is suspect. I've had 2 sets with runout issues varying from .005 to .035 out of round. Runout was primarily in the .025 - .035 range. Not good for a brand new wheel, worse for something you want to run on the track.
Addicted Specialist
Thanks, Michael! I'm really happy with it as well!!
Since I am photoshop challenged, a kind Rennlister put that together for me. Ya just gotta love this place![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Edward
Edward
If you are tracking the car, consider the unpsrung weight of wheels and the effect that has on
handling, response, tossability, tire wear....
Unfortunately, the really light wheels that keep your unsprung weight down, are also expensive, as opposed to the cup wheel repros etc that are cheap but made of cast aluminum and are anchors.
Not surprisingly, fuchs wheels are still some of the lightest out there [sans carbon fiber wheels], at around 16-17 lbs each. The next closest are the Fikse FM-5 and BBS.
As stated above, the track is not the place to use your cheapo wheels the street is.
Hope this helps,
Nick
Hope this helps,
Nick
uninformed gas bag
(contemplating on whether gas bag is one or two words)
Call CCW and tell them what you have and what you want to do and they will build wheels that fit for a price that is relatively inexpensive. I think my last wheels (9x17,11.5x17) were $2500.00
BBS wheels either one piece or three piece. Superlight have a panasport/minilight wheel you can use or go with a set of four seven inch wheels with spacers for the rear wheels. Like others have said - don't scrimp on track wheels - probably the most important safety device you have.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I do like the wheel up in yours though as well Edward!
Addicted Specialist
Keep your eyes on the classifieds. If you can go the CCW direction they know what you need, great service. Be careful on the Rota's not really a track wheel. Research Forged wheels.
