Clutch Issue
Yep, if you take it apart and the clutch is wasted get a new o.e. flywheel and pilot shaft bearing. You have to take the old flywheel off anyway in order to replace the crankshaft seal, so... The guide tube depends on wear, but you will definitely want to replace the release fork. You will want to order a stock, original, o.e. clutch kit.
Don't worry about the engine drop, once you start doing it you will realize how much sense it all makes.
