84 air always hot thru interior vents
Hi,
although I have the heat adjustment dial between the seats turned to lowest (coldest), and fan off, there is still (very) hot air blowing into the cabin thru the vents. This fault has only just occurred. I can bear it now, but when summer comes, I'll be toast.
I would be very grateful for any suggestions, comments.
Cheers
pete
'84 carrera
Cheers
pete
'84 carrera
-matt
Poseur
As an 84 model there is the distinct possibility that some of the foam-based seals in that ductwork are degraded,--significantly. Unless you go in and are prepared to repair or replace said ducts, things may not change. It can also be a control cable adjustment issue.
Man down under, I had the same problem on the '84. Turned out that when the guy (not my guy....oops, I mean not my mechanic) replaced the clutch he somehow jammed (two m's ?) the works so hot air was coming in, it was awful. So my mechanic fixed it with little effort and charged me maximum effort.
Neat color.....what is that?
