911 Forum 1964-1989
Fuel line rupture
Old Jul 28, 2008 | 07:32 PM
911vet's Avatar
911vet
Default Fuel line rupture
My car tried to warn me. For the first time, it failed to start on the first attempt. But it started on the next turn of the key.
Drove for 20 minutes before I smelled it. Gas.
Pulled into a parking lot and opened the rear deck. There was gas spewing all over the engine. I figured the flames would come before I could shut it off. Fortunately, no fire.
Had the car towed to a mechanic so I didn't end up doing the job myself.
I post this as a warning that you may not get much warning. Here's the line that ruptured. When in the car, the offending spot faces forward and isn't obvious. Once you know where to look, it's a spot you could monitor. But I'm not sure you can see it coming. It didn't look this bad until removed from the vehicle.
File Type: jpg
File Type: jpg
Old Jul 28, 2008 | 07:34 PM
Amber Gramps's Avatar
Amber Gramps
Glad to see you are safe.
That is why I do whatever Pete says. That hose is somewhat less than $20,000.
Old Jul 28, 2008 | 07:47 PM
911vet's Avatar
911vet
Another day of Porsche ownership, another $1000.
I'm getting used to it
Old Jul 28, 2008 | 07:50 PM
dshepp806's Avatar
dshepp806
Thank you for the reminder,......seriously!!
Best,
Doyle
Old Jul 28, 2008 | 08:36 PM
Amber Gramps
If you had a crystal ball you'd be $550 up right now.
Shipped 930-110-595-05-M260 Fuel Line (main line), 911 Carrera (1984-89)
Brand: OEM
1 $392.50
$392.50
Shipped 930-110-411-03-M136 Connecting Hose, 911 Carrera (1984-89)
Brand: OEM
1 $56.00
$56.00
but at least you are safe...
Peter Zimmermann's Avatar
Peter Zimmermann
Wow! When I wrote the most recent edition of my book I warned to monitor for heat cracks, as your line has, but I've never seen a fuel hose that lost a chunk of its casing! Good to hear that both you and your car are OK!
Old Jul 28, 2008 | 08:41 PM
Amber Gramps
One of us is just gonna have to post how to do this. My thread was 7 or 8 pages, but it could have been covered in a post or two if someone that could write would do it. Someday....
Old Jul 28, 2008 | 09:10 PM
old man neri's Avatar
old man neri
This might be a start.
-matt
Old Jul 28, 2008 | 09:37 PM
911vet's Avatar
911vet
Pretty horrible, isn't it? Hard to believe it could not be leaking just a day before. I feel very lucky except for the $500 I had to pay to have someone else do it. If I had followed your advice, I would have done it myself ahead of time.
By the way, the mechanic handed back 6 of the 12 gaskets and 3 of the 6spacers... saying they only had to remove one manifold. Does that sound right?
Old Jul 28, 2008 | 09:58 PM
JonH's Avatar
JonH
Sure glad this turned out OK for you, 1k is nothing vs. what could have been - you are lucky! I had a similar issue about 2 months ago. Started the 911 then went inside to get phone and wallet, came out to a running car with about a 2 ft. puddle of gas from a small hole off the fuel pump line. Good advice for all to check!
Old Jul 29, 2008 | 10:37 AM
Peter Zimmermann
I've never done the repair that way because I always felt that it would get the two sides of the intake out of synch with each other - kind of like polishing only one shoe. I guess that its OK, and that his decision was based on the condition of your old gaskets on the side that was removed. If your car runs well it should be OK, but I think the mechanic should have discussed his "short cut" with you first.
