84 911 starter - wiring help
Hi. I'm needing some help reassembling a project 911. The book I'm using doesn't go into great detail, and I don't know how the starter was originally wired.
Any help reconnect the wires to the starter would be appreciated?
Hopefully the attached image helps. The wires I'm not sure about are the following, the yellow wire, the green w/red stripe and green w/yellow stripe wires (these last two are attached to the body).
On the starter solenoid there looks to be a screw missing. I'm planning on getting a new screw, by using the other slotted hex head screw on the solenoid as a guide/template.
By the way, I'm new to the forum. My project is a 1984 911 Carrera. Not my first 911, but my first project 911.
Michael
Michael
![Name: starter.jpg
Size: 83.0 KB](https://rennlist.com/forums/attachments/911-forum/292457d1216704716-84-911-starter-wiring-help-starter.jpg)
I haddah Google dat
Just going through my external hard drive, posting pics that might be helpful later to someone:
(not sure what the Green and Red/green wires are though)
