Oil Level
Hey everyone,
I just got the 911 back a couple weeks ago. She is running strong. Put the new exhaust on last weekend as well. I will post a sound clip shortly for everyone to hear her purring. But I do have a question on the oil level. When the car is cold the oil level shows in the red. As the car warms up it is around
3-4 o'clock on the gauge, but when I hit the throttle it goes into the red again.
I know how important oil is for these older air cooled engines, I don't want to deprive it. I check the stick at warm idle and I am in the middle of min and max. Is this behavior normal? Is it just the gauge? Thanks everyone.
That's normal. The gauge is just there to give you a hint. To check the oil, get the engine up to operating temp (180 or so), then check it while it's idling on a level surface. You want the oil between the high and low mark.
Running a quart low is not as big a deal in a high-capacity oil system as it would be in a wet sump engine.
uninformed gas bag
(contemplating on whether gas bag is one or two words)
He's teasing us with that avatar. You should see the rest of it!
C'mon Jack show it all!
