Piston clearance?
Folks.
I am rebuilding a 3.0 SC engine for PCA racing. my P&Cs are in surprisingly good condidition and the ring lands are fine.
Piston aprons show wear of approximately .07mm. Piston to cyl clearance is about .08 mm.
If this were a street engine, I probably would re-use them, but for a racing engine, I'm concerned that this would allow too much movement of the piston.
I'm pretty much decided to buy new Mahle's,but before I pull the trigger, I'm interested in your opinions about how much risk the used pistons present
I think a little extra clearance in a racing engine is a classic thing to do - nothing like a free-revving engine that sounds like the pistons are changing holes when you start it cold!
Pete,
Thanks.
Yes, pistons were measured about 30mm up and perpendicular to WP as shown in my book. I'll bore-gage the cyl as suggested tomorrow. Just to make sure I understand, lets say cyl 1 measures 95.01 12-6, and 95.06 from 3-9... that would exceed your .04 max, and the cyl would be bad even though total clearance 3-9 of .13 is still under your .15 max? Correct?
BTW... why is that if you don't mind?
Thanks.
