911 Forum 1964-1989
A Visitor
Old Jun 2, 2008 | 12:48 AM
imcarthur's Avatar
imcarthur
Default A Visitor
I had a visitor today. The iceman (Clive) wanted to see the self-alignment process. Mr Self-Alignment Pro (that’s me) managed to strip a front height adjusting bolt 30 minutes before he arrived. Yeah, a dumbass move. I used the adjusting torsion bar end screw hole (did you get all that?) as a pry point when it wouldn’t come out easily. I must have burred it slightly & that started the screw haywire & by the time my dumbass brain kicked in, it was too late . . .
Anyway, we inspected it all & I did a pantomime alignment for him. And we talked DIY. We should do garage visits more often – except when dumbass is in the building . . .
And I remembered to pay him the $100 I owed him for a Hershey find.
And the search has begun for an adjusting screw. $37.25 from Pelican. Plus shipping. Plus border abuse & taxes. It nevers stops.
On the plus side, my short drive with Elephant PolyBronze front bushings (at the wrong ride height - seriously low) proved to me that they are no noisier than stock rubber. I would say a slightly improved 'feel' factor for side to side low speed 'tire warmup' sequence. I like them. I did the ball joints too btw so that factors in but overall more surgical in handling.
Anyways, nice to see you Clive . . .
Ian
Old Jun 2, 2008 | 01:19 AM
old man neri's Avatar
old man neri
Sorry to hear about your stripping problems Ian.
-matt
Old Jun 2, 2008 | 07:05 AM
Daniel Dudley's Avatar
Daniel Dudley
150.00 for two rear alignment bolts on the 928 a couple of years ago. Too much anti-seize. I was able to washer out one bolt to good threads and use a new nut, as a temporary fix. Good luck with the search.
Old Jun 2, 2008 | 08:46 AM
theiceman's Avatar
theiceman
Team Owner
hey Ian, let me know what the "other " place says we talked abiut, i'd be curious.
Old Jun 2, 2008 | 09:12 AM
imcarthur's Avatar
imcarthur
I am shooting for local if I can find one at a reasonable cost. I want it done & back on the road. At least the brakes worked - rebuilt caliper & complete bleed; the clutch worked - bled slave; the CV boots are all good - replaced another 2. And the EBs as above.
With my work sched & this car work = no time. Off for 5 days of southern sin in Nawlins Wed for The Pot Luck pro audio show. Happy hour starts at 4:30 . . .
Ian
btw keep your eyes open for a 911 in the 20 - 30 range. A new looker in Toronto - Mike - contacted me & he is sniffing around for a decent one. No prerequisites except he is thinking G50. I will encourage him to post.
Ian
Old Jun 2, 2008 | 09:18 AM
imcarthur's Avatar
imcarthur
Oh & a tidbit for Canucks. The castellated nut on the bottom of the strut requires a special wrench. Parts Source rents a kit with the proper socket for 1/2 drive. And it is a FREE rental. You pay for the kit in full & you are credited in FULL on return. Can't beat that. It wouldn't help for removal since you have to beat on it but perfect for reinstallation.
Ian
Old Jun 2, 2008 | 12:09 PM
imcarthur's Avatar
imcarthur
Success! $50 for the bolt & the adjusting cap. Brent @ Hunter. Pfaff was $46 & 4-5 days just for the bolt.
Ian
