Budget R-Gruppe 911? (Warning newbie question!!)
I am a big fan of these cars love the simplicity and the hot rod ideals of these cars.
please consider
-I can weld
-I can do bodywork
-I don't care so much about authenticity or rare parts
-I don't mind a later model motor
-If I can't afford it I substitute. If I can't substitute I make it.
-If I don't know how to do it I will learn.
-I am not afraid to learn paintwork or I will drive it in primer
-I would probably learn to sew an interior rather than pay someone else
What would you estimate the cost to replicate this style of car?
please consider
-I can weld
-I can do bodywork
http://www.tremotorsports.com/home.cfm
http://www.rgruppe.org/
The cost depends on where you start from. A long nose 911 would be much easier to start from than a later model. Call the folks at TRE. They've done quite a few and can give you a much better idea of what you are getting into.
If you can do most of your own work, somwhere between $5k and $50k+.
Keep looking around till you find somthing that has most of what you want with problems you can fix mostly with labor. Even a 912 could be a great R car.
Dose not have to have Fuchs wheels. Seen some rad cars with steel wheels. Some times you can buy a second car and get your money back on the parts you sell off...
I will not toutch a car with rust again, you could.
One of my cars was a 72T years ago that had a small motor fire. Just needed one set of plastic stacks ($40) an air cleaner and a little paint. Total cost, $2500. Was nice w 6" fuchs, ivory, new SSI's & solid motor. In today money migh be as much as $10k.
Bought a 914-6 project for $6k. Sold off the 7+8 Fuchs, transmission adn a bunch of parts and kept the 2.8 twin plug. Sold off my 2.4 T motor. Pickedup a set of 2.4 stacks & MFI pump. Bought a 2.7 RS space cam and installed it my self with tools I made. Inded up with the motor for free.
Found some 6.5 x 15 mini lights wheels on the cheap and bought some BFG R1 225/15 tires....
Cut down an aluiminum race seat and striped the interior.
That thing was faster than any twin turbo up to 70 mph.
Keep you eyes open, somthing will turn up.
