911 Forum 1964-1989
Fuel Problem?
Old Apr 28, 2008 | 09:10 AM
84_Carrera's Avatar
84_Carrera
Legacy Flounder
Head Temp Sensor going bad maybe? I know mine was horrible / would quit occasionally before replacing. I'd have to go back to... 2005 I think here to see the exact symptoms I posted about.
Old Apr 28, 2008 | 09:25 AM
paulh3.3's Avatar
paulh3.3
3rd Gear
Crap in the fuel tank being sucked through?
Old Apr 28, 2008 | 11:38 AM
Peter Zimmermann's Avatar
Peter Zimmermann
You're absolutely positive that the DME relay that you used is a known good? This is really a classic relay symptom...
The fuel pump is most certainly a possibility, but I don't know the mileage/history of your car. If the pump's original and you're over 80K miles I'd say that the pump is worth a try. I've seen times when the pump will "run" but can't keep up with engine need, and I appreciate that it's an expensive experiment, but...
Old Apr 28, 2008 | 12:48 PM
lfe132's Avatar
lfe132
Peter,
Yes, I tried replacing the DME relay with a know good one.
I purchased the car when it had 95k miles on it and it now has 138k on it. I have most of the service records from the PO's but not all. I believe its reasonable to assume that the fuel pump has not been replaced.
Also, note that the blower in the engine compartment turns on as soon as i turn on the ignition, it never did that before. Doesn't sound related but an odd coincidance.
Thanks for your input.
