What do i do with my dangly bits?
i'm a bit confused and would appreciate any help you can offer, am gonna fit k+n watershield air filters above my carbs. I have a filter/catch tank solution for the oil breather from the oil filler neck.
but what do you do with this hose? (red arrrows) is that a breather as well? it usually fits to a nipple on the standard airbox. but when the airbox is gone what do you do with the hose?
while i'm at it - shouldn't this brown wire (green arrows) be connected to something?![](http://www.smilie.dk/alm/c079.gif)
![](http://i215.photobucket.com/albums/cc271/louisjazzbalfour/IMG_1085.jpg)
thanks for any help.
1969 2,0 litre T with webers
thanks guys.
crimson, some k+n's watershields do have holes some don't (mine dont) but they are easy to put in. but i'm not sure they are necessary.
i "think" i've figured out the hose thing. in the part catalogue it runs to a valve/drain so i think its to dispose of moisture from the stock airbox. so just plugging it should be fine i "think"!?.
does that make sense to you guys in the know? (see parts 9 ,10 11 below)
![](http://i215.photobucket.com/albums/cc271/louisjazzbalfour/PET.jpg)
i've not seen many cars with it. but one i did see on pelican looks to be plugged with a bolt to my eyes. i pm'd him.
![](http://forums.pelicanparts.com/uploads11/IMG_67891191199779.jpg)
any more advice would be lapped up. THX
P
P
The breather hose you are refering to would just catch any oil in the air box and drain it to the back side of the engine. You can safely remove it or cap it. (Do not throw it away in case you go back) I can't see how any oil would accumulate in your shields anyway.
many thanks fellas for the good advice and knowledge. much appreciated.
the pesky fellow is now capped and stays for future backdate.
the k + n's are on and they scream and growl, together with a bursch muffler it brings a huge grin to my face with every single accelerator depression!
