Removing Oil Level Sender
Evening All. my '88 ClubSport is suffering from an intermittent Oil level sender. Can i remove this from the sump without draining the oil ? - anybody know the part number and whether pelican parts sell one ?
I just installed one in my SC today. I bought it from thepartsbin.com, it's the Porsche part in the box and everything. I didnt drain the oil, althought I might be a qt low.
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Good recommendation on the website, and also the timely hint. How had your sender been playing up ?...Mine hovers between a full scale delfection (short circuit) and very low / zero reading....
Steve
Steve
My sender read full most times, off the chart actually. Occasionally it would run low as well. I checked the wires at the sender and 1 was broken. I fixed that with the same no change. I have the exhaust off the car right now so I cant fire it up to check it, but I hope this fixes it.
