Started the valve adjust
Just take your time, Clive. I did my numerous times (3 or 4) over the course of a month before I was happy. I failed miserably at the footie method & ended up acing it with the backside method.
Since I was in there so frequently, I re-used gaskets & the nylocks. If you are really nice to them, you can reuse them several times. But don't tell anybody.
For a redo, you can also just tip the car to save the oil & just do one side at a time.
But then you won't have to know all of this since you'll get it right the 1st time . . .![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Ian
Ian
Team Owner
got all the valve covers off and cleaned up . tomorrow I will start the adjustments. It is very quiet right now so I am hoping I check them and they are fine.
I had the benifit of not having the cat in the way when doing mine.
the best thing that I did was buy some 1/2 in thick 24 x 24 foam pads to neal on and lie down on. I think they were for kids to play on, but they work great for saving the knees.
Flat and true valve covers-- there is a flat machinist stone block which is handy to have or you can use a medium size glass (always flat) window pane over a blanket on a flat concrete floor. Use medium grit cloth backed sanding sheet. Press lightly on the glass, hard as you like on the stone and rotate the cover in small increments 90 degrees with a back and forth sanding motion(as many times as you need). This will evenly sand the surface to flat. When all of the surface is the same color you can go to a lighter grit for a finer finish. I only use the medium.
I have had really good luck with a red rubber type valve cover gasket. They are sold by at least one popular Porsche parts vendor. I have used several sets on 2 cars made by another manufacture and have never had a leak and they can be reused and they do not stick and have to be scraped off-- price is good. Pm me if you need contact #.
I hope Pete will look at this and clue us in-- the feet seem to fall to one side so that there is a gap on one side and no gap at the other side. and you have to use a light to see which way they sit for the gap and insert the feeler in the gap to make it easier. I hope there is an easier way to get the feeler in. I seem to think it is too tight and then after messing with it for a bit get it in and the feeler moves between the foot and valve with a slight resistance which is just right. Got to be a easier way. Pete-- Peter??
Team Owner
Jake I will try to sand flat again .. although I am not covinced glass is always flat,, it is after all a liquid :-). I think my problem may be a leak somewhere else That is going to the lower most spot and making it look like the valve covers. I think I may have a leak at the base of the cylinders which IMO is not worth worying about for a few drops. As it means major tear down.
I like the idea of the read valve gaskets though . I have green ones right now. Think I iwll use those up and pick up the reds while in California next.
Team Owner
cause shipping over the border is a pain ... and hardly worth it. There pick up place is liike ten mins from the airport and I can swing by there easy enough
Team Owner
One additional question. When the rensioners were installed the feed line was tightend in the wrong position and stopped me from geting the passenger sidde upper cover off. I lossened it and of course oil came out. I have 2 new crush washer but do i have to do anything else > will the tensioner still be primed ? I think so but just wanted to ask as there seems to be no " return " line. how does this work ?
Ice, make sure they know you are coming. They do not have walk in service. AND the wearhouse is in San Francisco not L.A. I called them asked if they had will call and was told yes. Well, I got to El Segundo to find it a small industrial unit with a 4'x6' front office I had to be buzzed into. They do stock a fiew things in El Segundo (LA) but not much. Just call ahead and they will have it ready for you. I'm guessing you are going to be here anyway? How long will you be here? Any way ....
Team Owner
Yeah no kidding Doug I learned the hard way.. about the will call "room" . Actually I just got back . Our head office is in Fullerton but Air Canada only flys into LAX. I don't comlain. I actually just got back last week and will not be heading outagin for another 3 months or so .
Team Owner
and someone ususally spots something for me to do .. I know I have a lot of clean up work .. don't worry Pete no gratuitous Pics of brightly coloured painted parts.. which reminds me , I need to touch up my vice ..... hmmm..
