Late oil tank into early car?
Anyone know whether an oil tank from an '80s vintage 911 will fit into a '71 without cutting sheet metal? The reason is to make the tank compatible for a swap to a 2.7 liter.
Thank you.
Thank you.
RL Technical Advisor
[quote]Originally posted by Tom Frisardi:
<strong>Anyone know whether an oil tank from an '80s vintage 911 will fit into a '71 without cutting sheet metal? The reason is to make the tank compatible for a swap to a 2.7 liter.
Thank you.</strong><hr></blockquote>
Hi Tom:
You must cut some metal to fit the oil filler tube. This can be accomplished in a clean & sanitary fashion.
Its definitely worthwhile.
Hi Tom:
