Removing decals
Removing decals
I'm very tempted to take off my Carrera CS decals from my standard 3.2 in the pursuit of integrity. My question is, if I just peel them off is there anything I should worry about? Is the paint likely to be clearer and hence will there be a decal-shadow (technical term!) afterwards? TIA
In my experience decals tend to come off easier when heated with a hair dryer. Some adhesive may remain but should come off with some polish and elbow grease. Don't use any solvents harmful to paint(obviously). You may have some shadowing after removal depending on how long the decals have been on and the color of the car. Good luck!
The adhesive on emblems is a lot different that the vinyl graphics adhesive. A hair dryer will help a good deal, just don't try to cook it off and possibly soften the underlying paint surface. If there does happen to be any adhesive traces left, 3M adhesive remover will not harm a proper paint finish. Just waxing will remove it also, plus blend-in any ghost on your color paint. There may be the "Ghost" of the graphic left, but on your white car, it has a better chance of none showing. They are almost a sure bet to be on most metallic paint cars. Good luck!! Tony.
