Ballasted 1156 and 1157 LEDs
Anyone find a source of ballasted 1156 and 1157 LEDs, or a flasher that will work with regular ones?
I usually do not go in for blingy kind of things, but the 911 tail lights are small and low. I replaced the rear running light/brake bulbs with some large LEDs and it does make a noticeable difference. Now I would like to do the turning signals.
Steve
84 Carrera with 3.4 Andial
64 356C
Steve
64 356C
I suspect by "ballasted" you mean something like 9 ohm 10 watt resistors in parallel with at least one LED per side.
I installed an electronic flasher relay in mine, works fine with LED turn signal bulbs.
