911 Forum 1964-1989
80 sc headstuds
Old Jun 3, 2003 | 12:07 PM
Steve Zitelli's Avatar
Steve Zitelli
Post 80 sc headstuds
I know this a loaded question but what does it cost for headstud replacement and a new clutch on a 80sc euro at a reputable shop.
Old Jun 3, 2003 | 12:41 PM
Feeding a 911 for a while's Avatar
Post
You may get away with $2.5 - 3K but when the heads come off there may well be other 'surprises'. I had my headstuds done here in the UK and it cost £1500 with no other work apart from a throwout bearing for the clutch. I have since been told that it is a good idea to replace part of the clutch operating mechanism inside the clutch bellhousing as it is prone to break.
Old Jun 3, 2003 | 01:33 PM
Steve Zitelli
Post
Thats what I figured it would be thanks.Car suppose to have only 70k but who knows.
Old Jun 5, 2003 | 02:39 PM
John Adams's Avatar
John Adams
Post
If you only replace all 12 lower dilivar studs with steel ones and replace all the gaskets as needed, it cost around $300 in parts if you can do the work yourself. If you have to pay someone to do it it will cost alot more, ~ $3,000. I did mine last year. My engine had 107,000 miles on it when I did it.
Old Jun 5, 2003 | 04:43 PM
Mal's Avatar
Mal
Post
head studs, clutch, chain tensioners, popoff valve in airbox, major service, master cylinder, two brake caliper rebuilds, multiple hoses, etc about 5500 in DC. Ouch
