911 Forum 1964-1989
Coucours prep for Weber carburetors
Old Feb 25, 2008 | 07:13 PM
1QuickS's Avatar
1QuickS
Default Coucours prep for Weber carburetors
I would like some guidance as to what is considered correct restoration for the exterior of Weber carbs for the early 911s. Bead blasting bad; walnut shell blasting good? Don't blast, dip? What about surface oxidation after the blasting? Is there a hard wax that may be applied to slow the oxidation? Should the brass jet holders, etc be polished, replaced, or remachined to provide the same turning marks as original?
Also, I placed a thread earlier regarding the straw-yellow finish on some of the Webers which appears to be an alodine (chem coat) finish. Haven't had much success finding a solution. Pierce Manifolds said they didn't know either...
Any new thoughts besides why did I mispell concours?
Old Feb 25, 2008 | 08:40 PM
Peter Zimmermann's Avatar
Peter Zimmermann
The yellowish finish is really a tough one, and may no longer be environmentally possible to reproduce. I was never able to figure it out, or reproduce it, on the many Webers that I've rebuilt. I saw a few sets of carb bodies done by a machine shop (throttle bodies, etc.) many years ago, the finish was destroyed by sand blasting so I know exactly what you're trying to attempt.
Regarding jet carriers, I just polish them on a relatively fine wire wheel, which produces a nice finish.
If you contact PMO in Santa Monica Richard might have some answers for you - the best way to contact him is by fax (310) 394-6313.
Old Feb 26, 2008 | 11:40 AM
1QuickS's Avatar
1QuickS
Thanks Peter,
I've talked to Richard Parr about this already. I've been in contact with a restorer that routinely has his cars included in the Pebble Beach concours and his comment was walnut shell blast those items that cannot be replaced. I was hoping to get access to a concours judge for their input.
