Removing Passenger Air Duct
I have taken out the screw and I know there are supposed to be four clips like the bentley manual says but I cant find any simple way to get it done. The right side comes loose but the left side is just stuck no matter how hard I press on the clip with a small flathead screwdriver. Anyone have any insight?
I only removed the one next to the master cylinder while replacing the brake light switches. Why are you doing this? Don't tell me you are after a rattle or a squeek.
if you can get to both ends you may be able to "fish" it out. If you attatch a new wire to one end of the old wire you can pull thru the new wire and replace it that way. that is if you know what wire it is....
