911 non-starter
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Hi I'm new to the rennlist and new to Porsche! I managed to acquire a 1977 2.7 911 (with k-jetronic) just before xmas. The car has been parked in a garage for the last 15 years and is a non-starter. I've bee doing the usual things over the past few weeks like sorting the fuel system out, fitting new plugs etc. At the weekend I tried to start it for the first time - it didn't! Fuel is getting through, the CDS unit is whistling but I'm not getting a spark from the coil to distributor. The Haynes manual states that a reading of 0.4 to 0.6 ohm's should be between the earth and supply terminal (from CDS unit) - I'm getting over 2 ohm's! The manual also says that a reading of between 640 and 790 ohm's should come from the supply terminal and HT lead to distributor - I'm getting over 1600! Some sources say the coil is knackered and some say it's okay?
Does anyone have any sensible suggestion or other tests?
Iain <img border="0" alt="[crying]" title="" src="graemlins/crying.gif" />
1 Post
no hard answers.. but I'd clean the 14 pin connector in left side of engine comp. [to prevent voltage drop].. and the chassis to tranny ground[under car].. and check CD box voltage when starting.. then your distributor points and distributor/points ground..
TO me that sounds like a bad coil as well as something else going on.
Something else I would check would be is what's stuffed in your cooling fins. My 73T had a whole mice's nest on top of the cylinders. If I had tried to start it, I would have burnt up my engine in minutes. Shine a flashlight through the fan and take a look.
