915 Trans mount
Folks:
It turns out that "club sport" mounts ( aka. Cabriolet mounts) fit not only at the engine, but also at the transmission-end. Oddly, however, it appears that when used at the transmission end, you don't use the upper, large concave washer. Standard mounts at this location don't use the upper washer , either.
Has anyone done it that way, and what are the pros and cons?
--Wil Ferch
85 Carrera
--Wil Ferch
85 Carrera
Wil,
Haven't done this yet, but it's on The List. Thanks for the post. Could pls. pass along driving & shifting impressions when you get a chance. Have you noticed a difference?
Ted
86 Carrera <img src="graemlins/yltype.gif" border="0" alt="[typing]" />
Ted
1 Post
I did 4 sport mounts and can't tell...115,000 miles and welt. bushings..can't hurt IMHO..Where did the info for removing the washers come from??? I did the install using all the stock hardware.........Ron
RoninLB:
No one said anything about "removing" washers. I simply said that ( it apears) as stock...the front trans mounts use the washers on the bottom only, whereas for the rear ( engine mounts) seem to come stock with top and bottom washers. If this is the case, I was asking if anyone had ( instead) used both top and bottom washers on the trans side, and how it worked out.
--Wil Ferch
--Wil Ferch
