Momo steering wheel install DIY
Team Owner
ritzblitz please tell us you intimitaly know the girls in your Avatar and sig ! :-) may help us live vicariously through you .. and if you don't know them .. please lie .. :-)
I just installed a Momo wheel with Porsche horn button that has two tabs sticking out the back. The horn does not work when it plugs into either of the tabs. The horn works fine, in that when I touch the end to metal the horn goes off. Do I need to fabricate a splitter so that my horn wire can plug into both of teh tabs on the back of the horn pad? Thanks.
Was the new steering wheel attached to the steering column when you tested it? The horn button just earths the horn wire out so the wheel needs to be on for it to work. Other than that, the outside tab of the two needs a short earth wire on it so that it connects to hub. This will complete the circuit when you push the horn button.
Perfect, thanks. I followed your instructions and it works great. Thanks.
nice job! i wish i had this when changed out my wheel.... next step is to spin CC your speedo. the smaller wheel blocks 80-100 mph straight up and occasionally i glance down for a speed check (of course on the track) and it's difficult to see sometimes.
