Parts for SC distributor?
Does anyone know of a source for parts for the distributors used in the SC motors? I am looking, in particular, for the fiber washers on the shaft. These seem to get oil/heat fatigued and break, permitting the shaft to go up and down. I believe that this can impact the timing. It seems like massive overkill to buy a new distributor to fix this simple problem.
Tom Frisardi
Tom Frisardi
I have looked far and wide for the two bushings and the shim stock - no luck to date.
Bosch P/N 123-7010-00. It contains a new pin and a variety of washers and spacers.
PORSCHE P/N 930 602 922 00 -- I am told this P/N for the crush pins that hold the gear in place, but I have not tried to use buy one
0.1mm vertical play is what you are shooting for. Note if the plastic pieces are under the springs at the advance plate.
A very good thing to do to your car. I found an awful lot of crap in the dist. when I rebuilt it on my SC.
Jw
Jw
