Valve Adjustment Tools
I just finished the drivers side on my '83 Cab and only had one exhaust valve that was too loose, the rest were good. Has anyone found a screwdriver that will fit the valve adjuster and clear the Cat? I used a bit and 1/4" box end and it was a pain. I will do the passenger side tomorrow. By doing one side at the time I didn't have to drain the oil which was just changed by the PO.
I just have a regular stubby. Available everywhere. The one in the pic turned up from google image source. I don't actually own it.
Im sure you could buy a regular stubby and hack saw a bit of the end off.
