got her corner balanced
The car or the girl? Just kidding. Is it done with the car empty or do you sit in the seat or seats when it is done?
(I got pulled over and corner balanced by the CHP in my pickup a couple years back. I had to move the pallet of stretch wrap I was hauling forward 'cause I was too heavy on the rear tires.)
Team Owner
if you were to take 4 scales and put one under each wheel I imagine all scales would read the same ,and all heights are correct from the ground. Basically means the car is perfectly ballanced.
Ice, I know you guys use different math, and I am often just a smart *** punk that is to be ignored....but, 5 scales? did you over reach for the 4 or does your car have some other unspeakable something close to the ground that requirs an additional scale?
