1983 SC cab. passenger side PW quite working
DS side still works, so it's not a fuse. Does anyone have a wiring diagram? Where should I look first? The passenger side was working fine yesterday. I am suspecting the DS switch. Does anyone know that if the DS side switch quites working if the PS switch will quit too?
Thanks,
Aaron
Thanks,
Aaron
Note to self: check what you did last before blaming new stuff.
I had the PS door panel off to remove the outside door handle/lock cylinder. I let the door panel dangle a little bit by the power window switch wiring. It pulled a connector loose.
All fixed up (and down) now.
Aaron
Aaron
Mine does this once in a while after sitting a week or two. Wicke discovered nothing wrong but said I should not have shut it all the way when it sits. The motors in mine are new but sometimes lack power needed to start from extreme closed position.
He reached in through my speaker opening and unjammed it. Last time this happened to me I just had to try it again after the car warmed up and was running a higher RPM for more amps. Not a big deal. Cleaning all of the connectors could help, but my switches are new and it's tough to clean inside each of the little female plugs on the end of the wires.
