911 Forum 1964-1989
Pulled head studs
Old Nov 15, 2007 | 06:27 PM
gseclint's Avatar
gseclint
5th Gear
Default Pulled head studs
I am looking at a 1981 SC with 64000 miles and am wondering how common are pulled head studs on this engine? If the PPE checks out can this be prevented by proper maint. or driving habits?
Old Nov 15, 2007 | 06:34 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Hi:
Generally speaking, these engines never pull head studs out of the case like the older magnesium-cased engines do.
These DO suffer head stud breakage caused by long-term corrosion and its very easy to find a broken one after the valve covers are removed.
Old Nov 15, 2007 | 08:14 PM
MUSSBERGER's Avatar
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
I defer to the master.
Pete your assistance please.
Old Nov 15, 2007 | 08:30 PM
Peter Zimmermann's Avatar
Peter Zimmermann
The master already answered (but thank you for the nice words!)! Steve is absolutely correct, an SC with a pulled stud would be a rare event! However, the '81 SC is still in that broken head stud danger zone. The studs got much more reliable in '82, when Porsche finally started using the coated Dilavars.
Old Nov 17, 2007 | 09:10 PM
Naitove's Avatar
Naitove
I've owned my 81 SC since new. Last year I discovered I had 7 broken head studs.
Old Nov 18, 2007 | 12:34 PM
LaughaC's Avatar
LaughaC
omg! Who fixed it for you?
Old Nov 18, 2007 | 06:39 PM
Naitove's Avatar
Naitove
Daniel Jacobs at the Hairy Dog Grrrrage in Oxford CT. Did a top end plus new rod bearings, rings, reground cams, clutch. Car ran fine before. Now it runs like cat chased by a deerhound (inside joke.)
