911 Forum 1964-1989
'86 911 engine revving question
Old Nov 4, 2007 | 09:41 PM
justinsrx7's Avatar
justinsrx7
Default '86 911 engine revving question
A strange thing happens when I am stuck in traffic. My engine idles at around 1k RPM, but sometimes, for no reason, it starts revving from 1k rpm to 1.1k rpm over and over again as if i were pushing on the gas pedal every second or so. If I rev the engine to 4k or 5k rpm it sometimes stops, but often it just starts again when the rpm's get back to idle. Anyone every hear of that or experience that before?
Old Nov 4, 2007 | 10:20 PM
velo5338's Avatar
velo5338
7th Gear
Idle speed control valve. My '86 did it when it got hot. Easy to change out.
Mike
'86 911 Carrera
'87 930
Old Nov 4, 2007 | 11:05 PM
Amber Gramps's Avatar
Amber Gramps
your idle should be somewhere around 880 to 900 after you get that fixed
Old Nov 5, 2007 | 12:54 AM
justinsrx7's Avatar
justinsrx7
So is the ISCV something I should just replace, or are they servicable? If so, how? If not, do you know where I can get one?
Old Nov 5, 2007 | 07:02 AM
KC911's Avatar
KC911
Yes, you can clean the ICV with isopropryl alcohol (or something similar), and make sure the "plunger" is moving freely inside when you shake it. When I cleaned mine sometime back, it did "help", but still wasn't 100% correct, and I ended up purchasing a new one form Pelicanparts after a few months. Idle is perfect now...hope this helps.
Keith
'88 CE coupe
ps: I'm not one for "throwing parts" at a problem, but the ICV is sort of like a DME relay imo...you're going to need one eventually, so I bit the bullet.
Old Nov 5, 2007 | 11:34 AM
scottb's Avatar
scottb
Before changing the ICV, be sure the mixture is adjusted properly. A bad mixture can cause the engine to surge. If that doesn't solve the problem, the next thing you should try is the ICV.
Old Nov 5, 2007 | 11:52 AM
84_Carrera's Avatar
84_Carrera
Legacy Flounder
It may not be the idle control valve. Mine does this, I replaced the valve, same thing.
My car's running a Weltmeister Chip too, and the running rich thing is a possibility - folks have told me that up-converting the DME to a later year chip pinout & increasing the memory (replacing the chip) can help this condition... Helloooooo Steve Wong.
FYI... The generic (Wells) valve I got from Autozone at a fraction of the price turned out to be a Bosch.
Old Nov 7, 2007 | 11:38 PM
tone40's Avatar
tone40
Default My 88 Carrera had a similar symptom about a week ago...
So yesterday I decided to clean the ICV as mentioned. It also felt like the motor was not running smoothly when progressing from part throttle down to idle.
I used isopropyl alcohol then carb cleaner. When I started it up after cleaning, the idle jumping from 1K to 2K then back to 1K multiple times. I had confidence that it was just a temporary condition from the rich carb cleaner mixture.
Sure enough when I drove it today, it cured the un-smooth symptoms and the idle is perfect.
Thanks Keith et al.
Old Nov 8, 2007 | 07:24 AM
KC911's Avatar
KC911
Excellent! I was just passing along what I've learned from these boards, I (err, my "baby") couldn't live without them
Keith
'88 CE coupe
Old Nov 8, 2007 | 08:52 AM
tone40's Avatar
tone40
Default Isn't it great when you all you have to do is invest a small amount of time
to get your baby to run like a champ again? This car never ceases to amaze me.
Yet, there are other times...
