911 Headlight Malfunction
#31
Poseur
I believe you can do fogs and running lights and you don't have to have th eheadlights on. You do have to pull the headlight **** out one click. Have you discovered the "London Fog" parking lights yet? when the car is off and every thing is shut down, turn your left or right blinker on. It is a single side parking marker for narrow streets. Don't leave your blinkers on when you shut off the car. Is that cool or what?
#32
Well, I finally fixed my lights. I installed the Sucro relay kit and then bent the pins in the light stalk and they work great. I want to reinstall the steering wheel, and am wondering if anyone knows what the recommended torque is for a 1978 911 steering wheel bolt.
#33
2. Fit the washer and tighten the retaining nut on earlier models (those with a horn button) to a torque 58 lb ft or, on later models (those with a horn bar), to 54lb ft. Check that the flasher return striker operates correctly.
The above is from my "autobooks" for 1974 to 1977. hope this helps.
#34
