Draining washer fluid
Is there an easy way to drain all windshield washer fluid in a 87 911? Rather drain than circulate through windshield washer, or try syphoning. TIA.
All of the tanks that I've cleaned had to be removed. They frequently get nasty things growing inside, largely due to infrequent use. It's not a bad job to do, just dirty, and headlight washers complicate things. I think that gunlover05 got lucky finding a drain, although the factory may have added that on later models than I've repaired. I'm pretty sure that I've done a couple of early Carreras, but mostly it's been SCs and 2.7Liter cars, and I've never seen a drain.
