rough idling SC
8th Gear
I just changed the plugs from Bosch Super to Bosch Platinum, maintaining the same .028 gap. While the engine is smooth at high rpm, the idle is rocky and low at about 550 to 600. Does anyone know the proper gap for platinums?
Thanks,
Tony
83 911SC
Thanks,
Tony
83 911SC
8th Gear
Thanks. I checked the plug caps and all was fine. After driving for several hours, the idle has settled but is still at about 700. Can the idle be adjusted at the throttle body or is it adjusted via fuel mixture? It's an 83' ...
Tony
Tony
FWIW, I tried the platinum plugs in my '83 SC years ago, and they made the car run worse. I'd stick with the standard plugs. Have you compared fuel mileage with the two kinds of plugs?
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
I'll cast my vote for "standard plugs" versus platinums. I haven't had much luck in either of my cars with the platinums. Good ole' copper seems to work best, plus they're alot cheaper! <img src="graemlins/bigok.gif" border="0" alt="[thumbsup]" />
8th Gear
This is what I found... see if it makes sense to all (btw, my handle changed to my name from 964newbie...)
I kept the old plugs and measured the gap on each. They were all above .040 inches and worn. The idle adjuster was in quite a bit as well. I read somewhere that bigger gap = faster idle. I adjusted the idle and brought it to 900 rpm. While the acceration is smooth, the performace is not noticibly different than the "Super" plugs. I also noticed that the throttle response is not as crisp. At next tuneup, I may very well go back.
Thanks to all for your help.
