911 Forum 1964-1989
Initial start-up
Old Aug 9, 2001 | 11:57 AM
magistro's Avatar
magistro
Question Initial start-up
I'm about to start a fresh 3.2 for first time. What is the proper way, e.g. remove spark plugs and turn over until oil-pressure is attained or what?? Thanks.
Old Aug 9, 2001 | 06:32 PM
Joe Abbagnaro's Avatar
Joe Abbagnaro
Post
Yes remove the plugs... Also remove the Fuel pump relay so no fuel is pumping. Crank over for 15-20 seconds increments. You should eventually see the oil pressure gauge move.
After you have oil pressure do a quick once over to check oil lines and fittings that mignt have some leaks...
Good Luck
