77' 911S Emergency Brake Light
My emergency brake light on the dash comes on when I release the emergency brake, and goes off when I put the brake on. It just started doing this. Any thoughts?
Thanks,
Garry
Thanks,
Garry
Hi Gary,
The switch for that is at the base of the hand brake under the rubber cover. Lift the cover up and have a look. From memory it's not too hard to work out. Just two copper contacts i think. Watch the switch as you operate the hand brake.
Good luck
Good luck
