911 Forum 1964-1989
Hydra Stops
Old Sep 6, 2007 | 09:16 AM
TroyN's Avatar
TroyN
Default Hydra Stops
These are a small collar that lock onto chain tensioner "pistons" as a safety-net that keeps the piston from retracting fully in the case of a failure. I think they are intended for non-pressure-fed tensioners but I was wondering whether they would provide similar benefit for the Carrera tensioners. Maybe Steve W. could comment? Any input appreciated, thanks!
Old Sep 6, 2007 | 11:28 AM
1986951's Avatar
1986951
Default Tensioner Locks
You mean like these? I don't think there is enough room on the Pressure Fed Tensioners to install them, and the other issue is that if a tensioner starts to fail, you probably won't know it until the Lock has been shredded and all of that nice aluminum has entered your oil system! Just go with the Carrera Tensioners and listen to you engine!
File Type: jpg
Old Sep 7, 2007 | 01:38 AM
TroyN's Avatar
TroyN
Thanks for your help.
