oil cooler
6th Gear
Was I wrong in assuming that all 75 911S should have the oil cooler in the right front corner? If it isn't there, where is it?
Also, has anyone ever lubed the pedal assembly? On this particular car the whole set up has slight corrosion and i suspect that some lubrication after the clean up is needed - if so- are there particular strategic points? thanks for your help.
Former Vendor
Most 75s are not equipped with a fender mounted cooler. They do have an oil cooler on the engine itself. You can add a fender cooler if you need more capacity.
If you are having issues with the pedal cluster and lubrication I'd recommend you rebuild it using the aftermarket bronze bushings. They are dirt cheap and will eliminate slop from your worn nylon bits.
