Offset ball joints
I am trying to get more negative camber on my '87 911 with coil over suspension. Unfortunately, I have no more room at the top because the spring is bumping up against the chassis. I have heard about some offset ball joints that enables you to get some additional adjustment but I can't seem to find them. If anyone has any experience with these or knows where I can get them please let me know.
Thanks, red911
Thanks, red911
OS Balljoints are a good solution.
Also, what diameter spring are you using? If you are truly bottoming on the spring before full camber plate adjustment is reached and you are using a typical 2.5" diameter race spring, you could change to a 2.25" diameter spring to gain more fender and tire clearance. However, this may require modified perches as well so this solution may not be as simple as the offset balljoints.
